spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2008, 09:54 AM   #1 (permalink)
View philipjmarchese's Photo Gallery
USA spark plugs
just had timing belt, water pump & both other belts on my 2000 Camry. Was about $550.00 which I figured was about right. Car has 55000
miles. Dealer wanted to sell me new plugs & wire also. but i Did not go for them. I thought Camry came with platinum tipped plugs that go for about hundred thousand miles. Am I correct ?
philipjmarchese is offline   Reply With Quote
Old 01-13-2008, 10:57 AM   #2 (permalink)
Gameroom cash: $304355
I think the spark plug change recomendation for the generation 4 Camry was 60,000 miles. Check the maintainance section of your owner's manual to be certain.
Incidently, I think the timing belt change interval was 90,000 miles. You may want to check that out too Although it's a bit late, you will know for the next time.
Mike
Old 01-13-2008, 02:40 PM   #3 (permalink)
wtftoy's Avatar
View wtftoy's Photo Gallery
Iridium plugs last around 100-120k. I changed mines @ 87k with single tip ngk irdium plugs w/ ngk wires.
Timing belt is around 90k but I'l planning to have my local shop do mines @ 100k, haha we have non interference engines
1998CamryLEV6
Tokicos,Eibachs,TrdRSB,Intake,Jim'sTorqueRod.
wtftoy is offline   Reply With Quote
Old 01-18-2008, 11:17 AM   #4 (permalink)
View marc780's Photo Gallery
Might as well have had them changed then (or at least bought some new ones yourself to give to them during the t belt change and avoid their parts markup). Why, because the plugs are supposed to come out during the t-belt change anyway and the labor cost should have been exactly the same or only a few bucks more!
Old 01-18-2008, 05:55 PM   #5 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
The 2000 Camry plugs are supposed to be changed at 60 000 miles. You need twin ground double platinum plugs from Denso or NGK because of the way that the ignition system works in that car.
2007 Camry 2.4L 5M
Old 01-21-2008, 06:30 PM   #6 (permalink)
wtftoy's Avatar
So you're saying since I'm using single tip ngk's I'm missing/damaging something?
I'm driving a 98 toyota camry le v6
1998CamryLEV6
Old 01-21-2008, 07:13 PM   #7 (permalink)
It won't damage anything. They just won't last as long.
2007 Camry 2.4L 5M
Old 01-21-2008, 08:26 PM   #8 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
Why did you replace the timing belt so soon?
geoff5093 is offline   Reply With Quote
Old 01-22-2008, 03:32 PM   #9 (permalink)
Car is 8 years old. Heard someplace it should be done after 5 years. Is this correct or does just mileage matter ?
Old 02-03-2008, 03:29 PM   #10 (permalink)
NYR
View IvanHoe's Photo Gallery
if your talkin about single tipped platinums, then yes your right....but Iridium plugs only come single tipped and last as long or even longer then the traditional double tipped platinums.......
I also find the car to be peppier with my NGK Iridium IX plugs.
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
How to change spark plugs on 1MZ-FE under 1 hour albertezza Camry & Solara Lounge 25 06-23-2011 08:51 PM
Help me to understand timing PoR2GeEzCamry General Discussion 1 11-02-2007 11:14 PM
Spark Plugs for corolla 2003 neofx19 Archived Corolla threads 3 12-12-2006 09:14 AM
spark plug wires + spark plugs aleks77 Camry & Solara Lounge 4 09-13-2004 02:08 PM
changed spark plugs... engine light came on. sexydarin Archived Corolla threads 2 10-30-2003 06:21 PM
