Headlight wiring prob. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2003, 11:25 PM   #1 (permalink)
View rcj93cam's Photo Gallery
Just under the connector for the headlight bulb, the wire has pulled out. the light has been shorting out latly and i just would go up and giggle it and it would come back on, so i thought i would eventually check it out, well tonight the light just wont come on, so with the little bit out light that i had i saw that the wire has worn or pulled out of the socet. Main question, how much of the driver side headlight wiring harness do i have to replace? Or would it be easier to just splice a new socet into the wire? Thanks
I will look at it more tomar. when i have some light, maybe that will answer my questions, but any replys or suggestions will help. Thanks again
Reed
93 LE V6
rcj93cam is offline   Reply With Quote
Old 10-05-2003, 09:01 AM   #2 (permalink)
View woshiagni's Photo Gallery
It depends on what caused the wire to come loose. If the socket itself is damaged, it's easier (and more reliable in the long run) to replace the socket and splice in a new one.
woshiagni is offline   Reply With Quote
Old 10-05-2003, 09:20 AM   #3 (permalink)
thanks man, well its not the socket (i looked yest.) its the actual one of the wires just under the socket, it has pulled out of the socket completely. Still havent figured out how i am going to go about fixing it though.
Reed
93 LE V6
Old 10-05-2003, 09:33 AM   #4 (permalink)
If it pulled out and it's bare wire, you might need a new socket anyways.
If it came out with the contact, then you probably just need to take some needlenose pliers to reshape the contact and push it back in.
Old 10-05-2003, 09:28 PM   #5 (permalink)
Thanks man, i will try take a look again soon and see what i need to do. Thanks for the help.
Reed
93 LE V6
