OFFICIAL Gen. 3 Clear Headlamp DIY Thread - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Did you find this DIY Useful?
Hell Yeah! 97 67.83%
Nah man, too complex. 13 9.09%
Um yeah.....but could you still do it for me? 33 23.08%
Voters: 143. You may not vote on this poll
Old 10-04-2003, 01:03 AM   #1 (permalink)
H.I.D. Knut
View thisdj78's Photo Gallery
Ok folks, here's the steps to clear out your headlamp all in one thread.
Introduction:
I can't stress enough that you need patience to do this........if you try to rush or cut corners, you will mess up your whole project, which I almost did.
Just take your time, and before you know it, you'll be done. If you sand continuosly, you can get this done in one day......if you are a busy guy like me, then it may take you a week.
I would suggested buying a new or mint condition set of headlamps to work with.........using your old or faded lamps wont do you any good....because when lenses yellow and fade, its deep into the plastic so it will never be clear, no matter how much you sand. I used bronzemaxell's headlamp that he donated, it was faded, but for demonstration purposes it was fine.
You can find brand new headlamps on ebay for around $50 each.
MATERIALS NEEDED
- 1 set of new headlamps
- Thin flathead screwdriver
- 3M brand Sandpaper in the following grades (yes you need all grits):
60 grit
80 grit
100 grit
150 grit
300 grit
600 grit
1000 grit
1500 grit
2000 grit
- 3M Rubbing Compound
- Plastic Polish
- An Oven
All products I bought at either Walmart, Lowes, or Auto Zone.
STEP 1: Heating and removing lense
Pop off the retaining clips on the sides of the lamp, should be about 5 or 6 of them. Take out the bulbs, and if possible, remove all the black plastic mounting tabs......but if you can't, that's ok, you'll just have to make sure they don't touch any heating coils in the oven.
Pre-heat your oven to between 350 and 400 degrees, turn the oven off, then place the headlamp on a cooking sheet with foil underneath the lamp to prevent glue from dripping on the cookie sheet.
After 3-4 minutes, take the lamp out, slowly pry off the lense using the flathead. You may have to repeat this process 2 or 3 times untill the glue softens.
STEP 2: Coarse Sanding
60, 80, and 100 grit are going to be your course sanding grits.......this step is the one that takes the longest for these are the grits that will remove the texture. I suggest wetsanding to make things go by a little quicker.
I suggest you allow 1-2 hours of straight sanding time on each step if you would like to get it out of the way on one day.
you don't really have to sand hard, just steady and evenly, this will save your arm some strength.
^^^^ I'm only sanding the lowbeam section (in yellow) as if a projector were to be used...also to show the difference between the textured and clear side when I'm done. The areas highlighted in red are going to be the areas which require the most sanding because that is where the texture is the deepest, so be prepared.
Once you reach a stopping point, rinse the lense off to see where you are.
STEP 3: Medium Sanding (evening out the roughness)
For this step, you will be using 150, 300, and 600 grit. At this step, you will be evening out the roughness left behind by the course grit paper.
this is what it should look like as you are doing the medium grits:
STEP 4: Fine Sanding
In this step you will be using the 1000 and 1500 grit paper.
this is what the lamps should look like while you are on these grits, as you can see, almost no texture can be seen:
STEP 5: Finishing
You will be using the 2000 grit and Rubbing Compound in this step.
After you are finished with the 2000 grit, the lamp should look like this:
At this point, you should be able to run your finger on the inside and not feel any scratches.
Now its time to use the Rubbing compound which will remove the fine scratches and make the lamp crystal clear.
FINISHED
Here's what the finished product looks like.......of course, if you use a newer lamp, then it will be A LOT clearer then this......also you shouldn't have the imperfections on the sides, that's my bad from using the dremel.
UPDATE:
Here are some pictures of a member who recently sanded theirs 100%......it CAN be done!!
Thanks to Camry92LE for the pictures.........good job!!!
thisdj78 is offline   Reply With Quote
Old 10-04-2003, 01:38 AM   #2 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
vote for sticky!
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 10-04-2003, 02:09 AM   #3 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
2nd the sticky vote, or at least add to the ultimate sticky post
-Nick
Nick is offline   Reply With Quote
Old 10-04-2003, 10:19 AM   #4 (permalink)
H.I.D. Knut
Thanks yall!
Old 10-04-2003, 02:07 PM   #5 (permalink)
View silverstrand's Photo Gallery
super dope JOB great inspiration to the forum. STICKY!!STICKY! thats my vote. Once again camry have open a new door to the future. Thanks man
also r u thinking in the future of selling some or producing some of them cause if you do IM so iNN just PM me or email me.
silverstrand is offline   Reply With Quote
Old 10-04-2003, 02:11 PM   #6 (permalink)
Layd Customs
View InTeReX's Photo Gallery
Nice JOB man!! Finished product turned out really well. Mad Props to you!
InTeReX is offline   Reply With Quote
Old 10-04-2003, 02:37 PM   #7 (permalink)
Here
View Velocity's Photo Gallery
I vote this to be a sticky! You da man dj!
Velocity is offline   Reply With Quote
Old 10-04-2003, 04:43 PM   #8 (permalink)
H.I.D. Knut
Well I had mentioned earlier, that I may consider doing peoples lamps if they send them to me, but I could only do a pair every 2 weeks........and I would have to charge a premium price which would vary on the lamp and what part you'd want me to sand.
Old 10-04-2003, 06:03 PM   #9 (permalink)
View Tubbyc's Photo Gallery
damn.. dj.. that is amazing..
just out of curiosity, what does rubbing compound do?
Tubbyc is offline   Reply With Quote
Old 10-04-2003, 08:23 PM   #10 (permalink)
H.I.D. Knut
Rubbing compund removes the scracthes left from 1500 grit sandpaper.......makes it super smooth. It's almost like turtlewax but it's designed for plastic.
I even used it on my Camry's headlamps and it removed some scratches....made it look near new again.
It's made by 3M, the same folks that make the sandpaper........usually you can find the rubbing compound near the sandpaper, especially in auto body sections.
Old 10-04-2003, 09:56 PM   #11 (permalink)
H.I.D. Knut
Ok guys, I have an idea of what I want to charge.
But first, I want to see what you guys think it's worth to have your headlamp cleared out?
I want to be fair.....but again I need to be fair to myself for the time it takes to do it.
Old 10-05-2003, 12:53 AM   #12 (permalink)
Livers are for wusses
nobrainer's Avatar
View nobrainer's Photo Gallery
one of the best DIYs out there... you and ray ray should hook up
nobrainer is offline   Reply With Quote
Old 10-05-2003, 01:13 AM   #13 (permalink)
Nick's Avatar
this is a very long process no doubt you should calculate a pretty decent hourly wage, and its manual labour too
-Nick
Old 10-05-2003, 11:49 AM   #14 (permalink)
H.I.D. Knut
Yeah, that's why I posted the DIY because once I list my prices, I think people will rather do it themselves, lol.
Old 10-05-2003, 11:51 AM   #15 (permalink)
H.I.D. Knut
UPDATE:
I may be able to get my hands on a projector so I can show yall what the lamp will look like with a projector inside it and how the beam pattern looks!!!
