weird rear lights problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2008, 10:04 PM   #1 (permalink)
View icoben's Photo Gallery
4th Generation weird rear lights problem
I have a 4 cylinder 97 camry LE.
The white back-up lights dont light on and the left side of red back-up light also does not light on.
But when I turn the head lights on, the rear left red light is on!
That is the white lights will not be on. The left red light will only be on when I turn on the head lights.
The red back-up light on the right side is normal.
It is so wired!!!
I read the camry service manual (body_electrical), but still cannot find any answer.
Could anyone tell me what's wrong?? or give me some clue.
icoben is offline   Reply With Quote
Old 01-14-2008, 11:54 AM   #2 (permalink)
View freestylez's Photo Gallery
change the bulbs
2000 CAMRY CE
freestylez is offline   Reply With Quote
Old 01-14-2008, 03:41 PM   #3 (permalink)
Gameroom cash: $304355
"The red back-up light on the right side is normal."
Back up lights are always white.
If changing the bulbs as freestylez suggested doesn't fix your problem, then the next thing to do would be to open up the loom of wires inside the trunk, by the driver's side trunk hinge. Look for frayed or broken wires in there and repair as necessary.
Mike
Old 01-16-2008, 11:19 AM   #4 (permalink)
View marc780's Photo Gallery
Also could be your stalk switch but since the reverse lights dont go through that - hopefully you do not have TWO problems. change the bulbs and check the wiring run as the other two guys say, also another issue may be your reverse light switch on the trans needs cleaning, adjusting somehow, or replacing. (I'd get a junkyard switch myself, for testing at least)
Problem with Daytime Running Lights chargedmr2 8th Generation (1998-2002) 15 01-11-2008 08:24 PM
High idle problem w/ my 86. Weird problem bjamick Older Generations (1969-1987) 2 12-22-2007 07:32 PM
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 03:41 AM
weird shorting problem, need help tmarsh Camry & Solara Lounge 2 07-30-2006 03:50 PM
tail lights out, problem not the bulbs or the fuse jr_certs Camry & Solara Lounge 7 11-05-2002 12:11 AM
