» Site Navigation
» Buyers Guide
» Network Links
10-04-2003, 05:26 PM
#1 (permalink )
Senior Member
how many cfms does the 2.2L I4 take in
i would like to know how many cfm's (cubic feet per minute) of air the 2.2L Camry engine would take in at max load?
1998 Camry LE -- Black
Mods -Osram Silverstars -14inch Alloy wheels -Short ram intake
2001 Camry XLE -- Silver Bone stock
10-04-2003, 06:22 PM
#2 (permalink )
Bollywood Boy
that's kinda variable, cause think about it, the rate of air coming in at full throttle at 4000rpm is gonna be more than the rate of air coming in at 2000rpm.
therefore the airflow rate is a function of the engine speed i'm assuming...........i'm guessing........
am i right?
Mr. DIY
10-04-2003, 06:34 PM
#3 (permalink )
Senior Member
i got some equation off some site and i calculated 228cfm's at full throttle @ 6200 rpms. it might be completely wrong i'm not sure
10-04-2003, 06:52 PM
#4 (permalink )
Bollywood Boy
ahh that seems pretty damn low man, cause i know some computer fans do like 40 cfms, i was expecting it to be around like 1000cfms for like 6200rpms
Mr. DIY
10-04-2003, 07:04 PM
#5 (permalink )
that sounds about right most 4 cyl do around that
10-04-2003, 07:17 PM
#6 (permalink )
Official TN PimP
maybe u can boro a Computer fan into a turbo charger!
Blah
10-04-2003, 10:53 PM
#7 (permalink )
Senior Member
1000 cfm's NA yeah right buddy
here is some info i pulled off a supercharger site
CFM 850
Max Horsepower 500
External Scroll Diameter 9.0"
Front to Back Thickness 6"
Intake External Diameter 3.25"
Intake Internal Diameter 2.90"
Discharge External Diameter 3.0"
Discharge Internal Diameter 2.6"
paxton supercharger for V8's and 850 cfm boost is good enough up to 500 hp so if the camry is 1000 it must be pretty god damned powerful
10-05-2003, 02:56 AM
#8 (permalink )
Bollywood Boy
oh shiat, sorry guys, i guess my experience in this field sucks..........my bad
Mr. DIY
10-05-2003, 03:34 AM
#9 (permalink )
*The SV-11 Driver*
which site did you pull the info from?
2001 GTI VR6
1986 Camry (SV-11)
10-05-2003, 08:45 AM
#10 (permalink )
Very easy to calculate..........
U know RPM say 4000
if ur crank is doing 4000 RPM then your cam will spin at 2000 RPM.
Thus this means your going thru 2000 Timming cycles per minute.
(i.e. all cylinders go thru the 4 strokes of combustion)
Now take ur displacement multiply by how many times ur cam spins or simply RPM/2.
So you have a 2.2L well how many CF is that? i have no idea.
Lets work in Litres 2.2 * 2000 is 4400 Liters per minute.
That is, 4 400 000 CC a minute!
Now, 16.4 CC is one CID.
4400000/16.4 is about 268292 CID.
1728 CID in a cubic feet. (12*12*12)
268292/1728 is about 151.
SO About 151 Cubic Feet of air is sucked up by your engine every minute at 4000 RPM.
Where did i get this formula? I made it up using logic. IF you guys think its wrong please tell me why!
HOpe this helps.
- Vince
10-05-2003, 12:53 PM
#11 (permalink )
Bollywood Boy
what's a CID?
Mr. DIY
10-05-2003, 01:03 PM
#12 (permalink )
Grenaded piston
CFM = CID x RPM x VE ÷ 3456
CID = N (number of cylinders) x 0.7854 x bore x bore x stroke (all in inches)
Bore on 5S-FE is 3.43". Stroke is 3.58".
CID = 4 x 0.7854 x 3.43 x 3.43 x 3.58 = 132 CID
CFM = 132 x 6,200 x .8 ÷ 3456 = 189 CFM assuming 80% efficiency.
"Skoolin' the unlearned!"
10-05-2003, 01:05 PM
#13 (permalink )
Grenaded piston
Originally posted by mrbacardi
what's a CID?
cubic inch displacement
#14 (permalink )
Bollywood Boy
what's CID and VE stand for?
Mr. DIY
10-05-2003, 01:17 PM
#15 (permalink )
Grenaded piston
CID = cubic inch displacement
VE = volumetric efficiency
Heres the site I got the formula's from:
http://www.edelbrock.com/automotive/math.html
Linear Mode
