IAC and Coil on Plug question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2003, 10:17 PM   #1 (permalink)
View T28miata's Photo Gallery
How does the IAC work? Is it a stepping motor that open according to a frequency? I need to know so I can see if an standalone will work on the V-6 engine.
Also can the Coils be fired dirreclty from the ecu output or does an igniter have to be used?
Anyone have anyput?
T28miata is offline   Reply With Quote
Old 10-06-2003, 10:52 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
iac is controlled by the ecu
-Nick
Nick is offline   Reply With Quote
Old 10-06-2003, 11:01 PM   #3 (permalink)
of course it is, but I need to know how it's controlled does the ecu send it a frequecny that opens it or does the ecu send a voltage to open it and the opisite to close it?
Old 10-06-2003, 11:08 PM   #4 (permalink)
Nick's Avatar
pretty sure its voltage
-Nick
Old 10-06-2003, 11:51 PM   #5 (permalink)
yep got it figured out, the ecu sends +12 volts to ISCO to open the valve (below the 750 idle rpm) or it sends +12 volts to ISCC to close the valve (if above 750 rpm) And im pretty sure the coils can be tirgger from the ecu.
