1997 Camry will not start after adding Power Steering Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2008, 04:05 PM   #1 (permalink)
View Adamdale1's Photo Gallery
Over the last few days I had noticed that my car was difficult to steer and it would make a whiney noise, I checked the power steering fluid and noticed it was low so I purchased STP Power Steering fluid (instead of the recommended Dexron). After putting in about 10 ounces, the car would no longer start. It makes a rapid clicking sound when I turn the key, normally I would just assume this was a dead battery but is it possible I put the wrong power steering fluid in and this caused it?
Adamdale1 is offline   Reply With Quote
Old 01-20-2008, 04:11 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
No, it's not at all possible.
2006 Camry LE Special Edition
Old 01-20-2008, 08:54 PM   #3 (permalink)
camryLMT
View emg8186's Photo Gallery
Lightbulb
Just be careful not to fill the psf tank with too much fluid, as its hard to see the full line. I have added too much fluid to mine and had some starting problems which went away as soon as i drained some fluid out...oh and the type of fluid you used is perfectly alright. P
emg8186 is offline   Reply With Quote
Old 01-21-2008, 11:25 AM   #4 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $280492
View csaxon's Photo Gallery
Sounds like a weak battery.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 01-21-2008, 01:02 PM   #5 (permalink)
Gameroom cash: $304355
^ or corroded terminal connections at either the battery or the starter.
Mike
Old 01-30-2008, 11:53 AM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Do the above and check battery, terminals, and the connections etc.
Get a jump start, and then you will reassure yourself that the PS fluid did not hurt your car.
Search (Check out the DIY) for PS fluid change.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
'06 Avalon TSB ST002-06 Power Steering Noise Fix Mike Murrell 3rd Generation (2005-2012) 4 07-01-2011 10:03 AM
Camry V6 1997 Power Steering Pressure Hose shamjamal 3rd & 4th Generation (1992–1996 & 1997–2001) 7 09-24-2007 12:22 PM
Power steering fluid? noltian Archived Corolla threads 2 08-01-2005 10:30 AM
