my problem is similar, but a little different. Below roughly 32 degrees, she wont start.....however if I pump the gas pedal a few times she fires up. Could be you're running rich like me, hence why opening up the throttle on start up helps burn the excess fuel. It's an easy thing to test.
I've told about a dozen people that should know something like this and theyre all stumped, like how the hell would the car be affected by temps below freezing?
I've been told to check the o2 sensor and the coolant temp sensor....toyota has basically ruled out the o2 sensor.
edit; If that does happen, I would try cleaning the plugs and see if she run better, it's not a solution but more of a band aid till you can get it fixed.
If you insist on getting your way often enough, pretty soon you won't have to argue with anyone about it anymore
