On 2002-02-12 02:11, CAMRY300RR wrote:
u also need forged pistons
You don't need forged pistons with the kits that I mentioned above. The kits are designed to bolt onto a stock 5S-FE.
If your gonna run high boost then yeah you'll need forged pistons and a ton of other parts.
im gettin mine from JG engine dynamics they make one for the 5sfe ...
JG Engine Dynamics makes pistons?
Maybe you meant to say JE?
then u have to fix up the internals depending on how high u want to have ur boost to be... im thinkin of runnin approx 14psi minimum with an intercooler..
Forged pistons, billet rods (chromoly steel billet), ARP studs and bolts, metal head gasket, new main bearings and rod bearings, new rings, etc... This is for the bottom end.
You might wanna look into stronger valve springs, stainless steel valves, stainless steel retainers, cams, port & polish + 3 or 5 angle valve grind, extrude honing (maybe), etc... This is for the cylinder head.
By the way your gonna need a intercooler if you run 14psi. No if's, and's, or's, or but's about it. :grin:
Well good luck building your 5S-FE. I have a turbocharged Civic w/B18C1 swap running 19psi boost (still working on it) and i'm also working on a custom turbo kit for my 3S-FE thats gonna run at 7psi. :grin:
Boost is my friend. haha.. :smile:
