1991 Toyta Camry poors starting in cold weather - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2008, 09:53 AM   #1 (permalink)
View fromthestars's Photo Gallery
Hi,
I've owned a Toyota Camry 1991 4 cyl for almost 5 years. Hot or very cold, it would start on the first crank. I took it in for a major tune up to a reputable mechanic this past September. I noticed that as the weather turned colder it became harder to start. If the weather was about 40 degree F it would start immediately; if 20 degrees it would take around 3 cranks; if 10 degrees, about 8 cranks.
During the past week, the battery has been replaced, timing belt, thermostat, water pump; related seals have been replaced (all as part of normal preventative repairs). And yet, when the weather is very cold, it still takes multiple cranks to get it started. Before it starts, the cranks do not cause a partial start (sputter) until the one where it starts up, sputters a bit and then stays running.
Should I focus on anything where water can cause a problem in the fuel system when the temperature goes above freezing, the problem is minimal to non-existent. As it gets colder and colder, the problem worsens. Water freezes below 32 degrees and freezes more and more as the temperature drops and drops.
Does this make sense and what would you specifically focus in on? I'd appreciate your thoughts.
Thanks,
Nick
fromthestars is offline   Reply With Quote
Old 01-25-2008, 11:04 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $407595
View atobe's Photo Gallery
better check the coil on the distributor it's usually the cause for the car when it has a problem starting with moisture in the air.
Old 01-25-2008, 11:34 AM   #3 (permalink)
Thanks for replying... but as I understand it the coil/distributer was replaced when the car had a major tune-up several months ago.
Old 01-25-2008, 01:12 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The 3SFE engines had a cold start injector and a cold star injector timing switch. Check the resistance at different temps on the timing switch and check the fuel flow on the injector itself.
Kep
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
cold weather suspension blackedcoupeLE 3rd & 4th Generation (1992–1996 & 1997–2001) 7 01-24-2007 11:43 AM
cold air intake or short ram intake for my 1991 3sfe camry in AUS africanmarty Car Parts for Sale 0 01-13-2007 07:20 PM
Cold weather issue??? - Motor Noise from the front dash iralbuqu 5th & 6th Generation (2002-2006 & 2007-2011) 9 12-08-2006 09:17 PM
1991 camry needs help 1991_camry 1st & 2nd Generation (1983–1986 & 1987-1991) 1 09-22-2005 11:38 PM
