stock or aftermarket? gearheads only - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2003, 01:43 PM   #1 (permalink)
Official TN Rice Hater
97KaMuRi's Avatar
View 97KaMuRi's Photo Gallery
Unhappy stock or aftermarket? gearheads only
I was searching the forum and everyone that wanted to put turbo or their 4 cyl. camry's put on the stck turbo manifild from a 3s-gte. I wanted to put something other then a ct-26 turbo (after a rebuild of the motor). I was wondering could i put for example a aftermarket turbo manifold that could fit something like a t3-t4 turbo on my cam? i would appreciate the help mainly from tn's gearheads.
My Prelude
i have left the toyota family but will return soon enough
97KaMuRi is offline   Reply With Quote
Old 10-10-2003, 09:46 PM   #2 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
If you wait a bit i will be selling custom turbo kits and individual parts including tubular turbo manifolds.
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 10-10-2003, 09:59 PM   #3 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
Re: stock or aftermarket? gearheads only
Tony the Tiger is offline   Reply With Quote
Old 10-10-2003, 10:02 PM   #4 (permalink)
I am just a newbie!
You can always seek out on aftermarket turbos that would bolt up to a 3S-GTE (MR-2). Look for some MR-2 specific turbo upgrades and you should be able to find some aftermarket turbos.
You can also have an adapter flange made so an aftermarket turbo will bolt up to the existing turbo manifold. If not, you can always get the actual manifold modified with a T4 flange for example... You will need to buy a flange and you will need a welder to weld on a flange that matches the aftermarket turbo.
* Goal for 2012 -- 200+ MPH in the Camry
Old 10-10-2003, 10:02 PM   #5 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
For your needs a ct26 is more then enough so stick to the stock cast manifold its cheap and easy to find.
Old 10-10-2003, 10:34 PM   #6 (permalink)
97KaMuRi's Avatar
thanks guys thats all that i needed to know now i can go and make my wishlist for what i need to do for turbo. Actually i wanted to get a t3/t4 ballbearing hybrid after i do i rebuild of the motor and save alot of money. but any ways thanks.
My Prelude
Old 10-10-2003, 11:33 PM   #7 (permalink)
View warlock's Photo Gallery
Jzs147-rr
i tryed to ask shiftgate about the 1MZ is it going to be legale in Ca. USA? smog law stoped me in my setup,i was going to ue the supra setup i was toald the 1mz wount handel it but i now it will
(i.e.tony) if i can get a setup aand keep it smog legal i want a kit
warlock is offline   Reply With Quote
Old 10-11-2003, 10:17 AM   #8 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
Its easy to pass the smog but the visual might be a problem in CA since I would need to get my kits 50 state tested and approved.I already have a kit for then non CA cars but I could probably adapt the kit to fit your car too.
Originally posted by warlock
Jzs147-rr
Old 10-11-2003, 10:44 AM   #9 (permalink)
thanks man
