Socket size of oil pan drain plug - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-17-2003, 07:24 PM   #1 (permalink)
'04 Camry XLE V6
Kooter's Avatar
View Kooter's Photo Gallery
Question Socket size of oil pan drain plug
Can anyone tell me what socket size I need for the oil pan drain plug on a '04 V6 engine?
Also, does the drain plug use a metal crush washer? And if so, does anyone have the Toyota part number for it.
Thanks,
Kooter
Kooter is offline   Reply With Quote
Old 10-17-2003, 07:29 PM   #2 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
all toyota uses 14mm, except for few old ones, like 7M-GE, etc etc
usually, they use paper wahser, and you can get them from your local mech....it doesn't reallymatter which to use, metal or paper, justto remind you, those washers are also used so you can't over tighten the drain plugand not strip the thread on the oil pan.....so don't over tighten, and don't use any leverage. does not need to be tighten hard!
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 10-17-2003, 07:57 PM   #3 (permalink)
'04 Camry XLE V6
Kooter's Avatar
Thanks for that information.
Yeah, I've been changing oil in a BMW M3 for a few years and always use the recommeneded torque for the drain plug so there's no chance of stripping the threads. It's a natural tendency to want to overtighten it.
Do you happen to know what Toyota recommends that the drain plug be torqued at?
Kooter
PS - Where in NYC are you located?
Old 10-17-2003, 08:06 PM   #4 (permalink)
Druken Postwhore
TRDragoon's Avatar
im in Toronto man,......North York Ontario
im not too sure what's the torque spec,......i just use all my strength with my skinny arm j/k
The AE92 Master
UniQue_N_RaRe
Old 10-17-2003, 08:14 PM   #5 (permalink)
'04 Camry XLE V6
Kooter's Avatar
Okay on being in Ontario!
Maybe someone has the torque specs on the oil pan drain plug.
Kooter
