brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2003, 01:52 PM   #1 (permalink)
The All Mighty POO
View Pooter8D's Photo Gallery
brakes
Is there any way to improve the responsiveness (if thats a word) of the brakes in my cam??? Like i want the brakes to be triggered on a lite touch, rather than pushing the brake half way till i feel it slow down. BTW my break pads are fine, and i think i might buy a pair of cross drilled and slotted rotars soon, but i would still want to make it more responsive
Pooter8D is offline   Reply With Quote
Old 10-20-2003, 01:59 PM   #2 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
I hear that replacing the stock rubber brake lines with braided ones will help for that.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 10-20-2003, 02:27 PM   #3 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
HELL YEAH IT WILL... with Braided Lines you can crush them pads into the rotors like all hell! Ha ha ha!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 10-20-2003, 02:40 PM   #4 (permalink)
View luisitol's Photo Gallery
so who makes SS Line Kit for the Camry? Or would one be beter off just buying SS Braided line and measuring it off ourselves?
'93 Probe GT - Daily Driver
'93 LE - Show Car - Coming SOON
luisitol is offline   Reply With Quote
Old 10-21-2003, 08:26 PM   #5 (permalink)
pdpchasm's Avatar
View pdpchasm's Photo Gallery
tirerack.com or u can look at Rod Millen's SS brake lines @ rodmillenstore.com
btw i am talking about gen 3s, not sure if any other gens are available on those sites.
pdpchasm is offline   Reply With Quote
Old 10-21-2003, 09:07 PM   #6 (permalink)
View warlock's Photo Gallery
www.nopi.com
warlock is offline   Reply With Quote
Old 10-21-2003, 11:47 PM   #7 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
high performance pads (kvr or whatever), slotted rotors, so you always have fresh pad making contact
and you might want to bleed the system, maybe replace the fluid with dot 5 or that high temp ford stuff
-Nick
Nick is offline   Reply With Quote
Old 10-21-2003, 11:47 PM   #8 (permalink)
Scuzzle-butt
xavior66's Avatar
View xavior66's Photo Gallery
Not trying to stop you or discourage you by any means at all, but on a side note, stainless steel brake lines will not actually improve your braking performance (ex. won't reduce how long it takes your brakes to stop your car.) But since from the sounds of things you want more responsiveness from the brakes, then yes, definetly invest in some stainless steel brake lines. What they will actually do is "firm up" the brake pedal feel, so in other words, like a short-throw shifter is to a tranny, ss lines are to brakes. Your braking will feel more positive and *ahem* "precise." See, your stock rubbery lines give your brake pedal that mushy-like feel because the pressure from the master brake cylinder on the brake fluid causes your stock lines to flex somewhat, which sometimes causes a slight disturbance in the force (beginning to sound like Star Wars here :P). Stainless steel brake lines, however, are not as easily flexed, so the force and pressure running through it is basically able to travel all the way through the line, without having to deal with all these lil movements the rubber lines would cause otherwise.
Phew!
It's not what car you have, it's what you do with it that matters.
Packing your lunch in a paper bag-$5.00
Eating your lunch you bought on an airplane-$50.00
Losing your lunch from the airplane's cuisine, but not having a paper bag-Priceless
For everything else, there's paper bags!
xavior66 is offline   Reply With Quote
Old 10-22-2003, 12:19 AM   #9 (permalink)
View silverstrand's Photo Gallery
Nice Info xavior66
silverstrand is offline   Reply With Quote
Old 10-22-2003, 06:32 AM   #10 (permalink)
oranz's Avatar
View oranz's Photo Gallery
this is how the cam's breaks work... thank god for the ABS on my gen 2 camry
This is the life we chose... the life we lead... there is only one guarantee - none of us will see heaven
oranz is offline   Reply With Quote
Old 10-22-2003, 10:23 AM   #11 (permalink)
View gqdabien's Photo Gallery
I just had my drums/shoes entire rear braking repalced along w/ evening out the front rotors and new kvr pads. However my breaking is stil very sluggish and i feel that i have to put alot of force down to stop the car and also keep it stopped at red lights. If i start to ease on teh brakes but still have it somewhat depressed, the car will start to roll foward.
Is this a symptom of a leaky brake master cylinder? I see a small amount of fluid leaking from where the master cylinder connects to the power brake booster.
I can't tell if its because of faulty master cylinder, faulty brake booster or if camry's are just like this?
Also, does neone else get a rubbing kind of sound when u release the brakes slowly? It sounds like it comes from the back.
Thanks Alll
Jeff
gqdabien is offline   Reply With Quote
Old 10-22-2003, 08:58 PM   #12 (permalink)
The All Mighty POO
thx for the replies guys.. gunna look into that stuff
