Changing Air Filter? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2008, 03:26 PM   #1 (permalink)
View SilverCamry02's Photo Gallery
Gen5 Changing Air Filter?
How do you change an Air Filter on a 2002 4 Cylinder Camry? I loosened the 2 bolts on the housing but I had a really hard time getting the cover off and I didn't see any clips. What else do I need to do? Pictures would be helpful!
SilverCamry02 is offline   Reply With Quote
Old 03-04-2008, 04:35 PM   #2 (permalink)
Gameroom cash: $284230
View LE05's Photo Gallery
make sure the bolts are all the way loose. then pull up and to the right... there are two "tabs" on the left of the box that lock that side in.
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is online now   Reply With Quote
Old 03-08-2008, 11:25 AM   #3 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
make sure you unscrew the O2 sensor, since it snags. I changed my filter yesterday to the TRD high flow. after you get the 02 sensor off, you'll have more slack.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 03-10-2008, 09:06 AM   #4 (permalink)
Thanks I did it Yesterday! I still had a little trouble even though I removed some things connected to the Air Filter Housing. It sure is a well built car!
I noticed after I put the Air Filter in the housing and screwed down the 2 bolts I could seen the white edges of the Air Filter. I checked and it is in the right way. Then what really trouble me was when I turned on the car it sounded a little rougher than before. Is this normal?
I put in a Purolator Air Filter which seemed to match up with the old one. It just doesn't seem like I should be able to see the edges of the Air Filter or that the car should be running rougher. It should be running better! Can somebody shed some light on this?
Old 03-10-2008, 11:29 PM   #5 (permalink)
Asian N00b Modder
Gellenole's Avatar
you're fine, the TRD filter sticks out a bit too, just make sure all the screws are tight and the left clamps along with the front clamp is aligned and sitting properly.
