New here, tech help needed! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-21-2003, 12:52 AM   #1 (permalink)
View jpete's Photo Gallery
I'm working on a friends car, a 92 Camry with a 2.2. It cranks but won't start. The spark seems weak or intermittent. Is there a way to test the coil or ignition control module? Or possibly a way to flash out any trouble codes? Basic stuff is OK. Cap/rotor/wires/plugs are all new. I can smell fuel when I crank it so I think the fuel pressure is OK but I couldn't find a Schrader valve to see if there was pressure at the rail. Is there one there? He just had a local garage do the timing belt 'cause "they said" that was the problem, I'm just trying to help him not ge screwed any further.
Any help would be appreciated. Thanks
Jeff
jpete is offline   Reply With Quote
Old 10-21-2003, 01:08 AM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
ok, i dug out my haynes manual just so i could get this right
measure resistance between the positive and neg, the 2 that are on that one clip, that's the primary coil, resistance should be 0.4 to 0.55 ohms
check the resistance in the secondary winding, take the coil with the high tension wire (that goes to the distributor cap) on top, and the positive, which is the one on the left if the high tenstion wire is on top
that should between 9.0 and 15.4 Kohms (don't forget to change the scale)
i'll read up on how to check the ignitor
-Nick
Nick is offline   Reply With Quote
Old 10-21-2003, 02:01 PM   #3 (permalink)
Thanks for the help. I'll check that out.
Jeff
