dont see why you have to use dots on the belts to do the timing job. perhaps ppl should be adviced to ignore the damn dots on the belt? hhaha
the main problems when changing a timing belt are caused by confusion i think, here are some common mistakes (and the first things to check if difficulty is encountered during the belt change):
-Crankshaft mark may have been 180 degrees off and not at TDC. (normally if the camshaft pulley marks line up at the same time as your crank mark, you can be pretty sure you are at TDC though.)
-The belt (for V6 at least) should have the three alignment stripes. (if they are not legible or missing for some reason, the old belt should be used to mark the new one).
-the belt probably also has a fourth mark, an arrow showing either direction of rotation (of the engine) or pointing out away from the engine. Usually the fourth mark would have writing on there too to help you install the belt right.
So in other words, pay attention to the fourth mark or its possible, on some engines, to have all your marks line up but your belt is actually on
backwards.
If the forth mark is absent, again you can use your old belt to help orientate the new one (by matching the new belt marks to the old belt as installed and making your own arrow with white out.)
i think when the crank is literally one degree or more off, you didn't do the hyd tensioner installation proper. you make it off a little on purpose before installing it, such that the hyd tensr, once installed, makes it all line up. or get lucky by just sticking a bunch of slack on that side [firewall].
Many people have apparently had this problem but i found that its not hard to avoid...you can make all the belt marks line up with all the dots on engine and pulleys easily.
When you install the belt, start at the crankshaft gear. Use a zip tie or cord to lightly hold it in place, then place your belt on the water pump pulley (under i think but i forget, its all in my detailed post under "V6 timing belt" search). then move up top and put the belt on your front cam pulley. Snake it under the top tensioner then try to put it on the rear pulley, the belt will probably not line up now. So just take a 17mm wrench, turn the front cam pulley
just a little bit in the CCW direction. Now your belt and all the dots should line up.
If you have everything lined up like this and took the tension out by doing the previous step, all the marks ought to be dead on.
