"Check Engine" light help needed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-22-2003, 08:27 PM   #1 (permalink)
'04 Camry XLE V6
Kooter's Avatar
View Kooter's Photo Gallery
I have a friend with a '94 Camry 4-cylinder who had the starter rebuilt today. Now the "Check Engine" light is on.
I believe the battery was disconnected during the process of checking out what was wrong with the car. Is that (disconnecting the battery terminals) the reason why the "Check Engine" light is now on? If so, what needs to happen before the light goes back out? Will just driving the car a few days (x number of on-off cycles) do it?
Thanks for the help!
Kooter
Kooter is offline   Reply With Quote
Old 10-22-2003, 10:03 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
i don't think unplugging the battery would trigger the cel to go off, i suggest going to kragen or whatever and getting the code pulled
although a certain number of cyles would turn it off if the problem isn't there anymore
you can try resetting the ecu (unplugging the battery for a few minutes) and the cel will probably come back on
get the code pulled
-Nick
Nick is offline   Reply With Quote
Old 10-22-2003, 10:31 PM   #3 (permalink)
View OEMonkey's Photo Gallery
you can check for DTC's yourself with a paperclip, pen, and paper.
maybe the ignition was switched to the on position when a sensor circuit was disconnected. if you clear the code and it doesnt come back then thats prolly what happened.
OEMonkey is offline   Reply With Quote
Old 10-22-2003, 10:58 PM   #4 (permalink)
View JeffTsai's Photo Gallery
what code are you guys talking about?
Also, you can pull the batt for a few min. And put it back on as someone else mention earlier in the post. Thats what I do and it usually fixes it. However, if it goes out after you reset then comes back a while later then you proabably want to take your car to get it checked.
05' Lexus GS300 Crystal White
Electrical & Lighting: Custom M5 Bi-Xenon HID Retrofit (Done by me), HID Foglights 6000K, Optima Yellow Top
Suspension & Brakes: Tein Flex Coilovers, SupraTT 4pot Calipers, G-Stop SS Lines
Engine: L-Tuned Exhausts, SRT Intake
Boost in the summer 2JZ Power!
JeffTsai is offline   Reply With Quote
