Transmission Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2003, 03:00 PM   #1 (permalink)
View drugal's Photo Gallery
Transmission Plugs
Hi, I'm trying to change my transmission fluid. It's an '89 3S-FE 5spd.
Can anyone tell me if I've got the right plugs in this picture? I don't want to be taking out the wrong things. Thanks.
drugal is offline   Reply With Quote
Old 10-26-2003, 04:20 PM   #2 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
Looks pretty much like mine on my 2000, so I'd say looks good.
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 10-26-2003, 05:01 PM   #3 (permalink)
Druken Postwhore
TRDragoon's Avatar
View TRDragoon's Photo Gallery
do you have tranny fluid dip stick??? you can also fill from there....
The AE92 Master
UniQue_N_RaRe
TRDragoon is offline   Reply With Quote
Old 10-26-2003, 06:00 PM   #4 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
According to diagram 32.3 on page 56 of the 1983-1991 Camry Haynes manual, your diagram is perfect.
Also in response to TRDragoon:
Manual transmission Camry's don't have dipsticks. The only way you can check it is by using the filler hole.
I suppose tranny fluid isn't as important to a 5 speed??? It's kinda screwed up if you ask me :P
90CamryDx3SFE is offline   Reply With Quote
Old 10-27-2003, 09:34 PM   #5 (permalink)
View OEMonkey's Photo Gallery
make sure you remove the fill plug first before drain plug. it would suck if you drain the fluid first then find out later that you cant remove the fill plug.
OEMonkey is offline   Reply With Quote
