Big bump/jolt when letting go off throttle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2003, 07:16 PM   #1 (permalink)
View aleks77's Photo Gallery
Angry Big bump/jolt when letting go off throttle
I noticed this happens around 65-85km/h when im crusing in 4th (auto) and my foot is slightly on the pedal, to keep the speed (around 2k rpm), or even to speed up a bit, and then if i let go off the throttle, I get this jolt sorta - its fucking annyoing, hard to explain, its not very noticible but very annyoing and i think something is fucked
Thanks.
1985 Toyota Camry, 270,000kms.
aleks77 is offline   Reply With Quote
Old 10-26-2003, 07:23 PM   #2 (permalink)
The All Mighty POO
View Pooter8D's Photo Gallery
is it when the gears are changin?? cause thats what my cam does.. but that has 170K on it and i can tell tranny isnt top notch no more.
I'm guessing it momintarily slips into an (auto) nuetral and with that u get a bit of a forward jolt as there is no more engine resistance
Pooter8D is offline   Reply With Quote
Old 10-26-2003, 07:37 PM   #3 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700165
iTrader Score: 6 reviews
View EKam's Photo Gallery
so does it jolt when you speed up or cruising?
when was the last time you change your tranny fluids? is it synthetic?
18/6/08 - Sayonara Kamuri!
EKam is online now   Reply With Quote
Old 10-26-2003, 09:51 PM   #4 (permalink)
no idea when tranny fluid was changed, um, its like what he xplained, like dropping it into N and back.....I'll get toyota to check it out.
Old 10-26-2003, 11:47 PM   #5 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
Could be the engine rocking back and forth if your engine mounts are bad.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
