ECU chips - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2003, 08:11 PM   #1 (permalink)
View SE V6's Photo Gallery
ECU chips
Howdy,
Has anyone heard or tried an ECU upgrade for the 4sp auto tranny for a Gen5 V6 camry? Any performance ones out there? I was thinking along the lines of being able to hold rpms until you shift manually (via L, 2,etc.) even if it is before redline. Not to be confused with the stock setup but almost like a semi-auto setup. Whenever you shift up, it shifts up into that gear. Likewise, if you select 2nd or 3rd, it will not only hold that gear, but it will stay or start off in that gear selected.
One thing I've noticed (for a very long time...heck when I just bought the car 2 years ago) is that if you can upshift before the stock computer does ie. 5300rpm @ WOT, the car would be much quicker.
I'm also interested to hear of any true performance chips for the same non VVT-i V6 motor.
If anyone has any bites on this one or anything similar, please lemme know.
Thanks!
SE V6
SE V6 is offline   Reply With Quote
Old 06-22-2004, 10:20 AM   #2 (permalink)
4u2nv
kasimmmmm's Avatar
View kasimmmmm's Photo Gallery
i have the same question... does anyone know?
kasimmmmm is offline   Reply With Quote
Old 06-22-2004, 10:26 AM   #3 (permalink)
Mad Scientist
2wickedtoyz's Avatar
Gameroom cash: $248601
iTrader Score: 9 reviews
View 2wickedtoyz's Photo Gallery
just tighten your throttle cable on you'll feel the car become more responsive...is that what you wanted?
[url]http://www.cardomain.com/id/wickedtoyz[url]
Camry Wagon Crew
2wickedtoyz is offline   Reply With Quote
Old 06-22-2004, 10:42 AM   #4 (permalink)
Gameroom cash: $147537
Its not ECU chip. ECU doesn't control the tranny at all. It just control engine function: fuel, ignition and a few idiot lights.
What you looking at is a full tranny upgrade to semi-auto. Yea it'll be costly $3000-$5000 I'll say. I believe I've read something on the net about full race sequential tranny upgrade. You'll better do a manual swap.
Old 06-22-2004, 10:47 AM   #5 (permalink)
Why not?
LiLItalian's Avatar
View LiLItalian's Photo Gallery
speaking of tightening the throttle cable, i tryed doing that and got completely lost, can anyone help me with that id greatly appreciate it.
Ive seen ECU spgrades for Gen 4 Camry's before but forgot the company that made them... i'll try to find it, they were very $$$
SOLD!
97 Camry V6 TRD
Proud new owner of a 2005 Scion TC
5-speed baby!
Toyota = Love
LiLItalian is offline   Reply With Quote
Old 06-22-2004, 02:36 PM   #6 (permalink)
限界域への独走。
View mobes's Photo Gallery
Then how does the ECT button work?
The shift points are controlled by the ECU. I'm not sure about gen2 Camry's, but gen3 and up have ECT (Electronically Controlled Transmission)
mobes is offline   Reply With Quote
Old 06-22-2004, 03:18 PM   #7 (permalink)
Ok just checked Toyota manual, it is the same box. ECT equiped tranny got a different ECU with bigger plugs.
This acturally make it worse. Someone gotta specialize a chip for that ECU. Its already hard to get ECU chip not to mention ECT E CU
On another note, the ECT measure engine torque and adjust shift point accordingly. So you may not need to change anything. Maybe just change the torque converter?
You could probably connect switch directly to the solenoids and bypass the ECU for manual shifting. Don't know if that gonna grind the gears or not.
Old 06-22-2004, 06:59 PM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
ECT changes the shift points. When its in PWR mode, it shifts at higher rpms.
Changing the torque converter will just give you a higher stall speed (rpm).
"Skoolin' the unlearned!"
Old 06-27-2004, 11:08 PM   #9 (permalink)
View 04sev6camry's Photo Gallery
there is and ECU from www.jetchip.com i had one in my truck and the gain was noticeable...the only difference between my truck and my gen5 is that my truck had an inline upgrade (went between the ecu and the harness and changed the inputs for more power) the upgrade for the camry is one where you mail you ECU to jetchip and they reprogram it and then mail it back. i heard it takes about a week so i havent done it yet, but i plan to whenever i can go without my car for a week. plus it costs about $500 so it isnt cheap.
by the way SE V6 the gen5 V6s have a 5 speed auto trany, the 4 bangers have the 4 speed auto. just FYI.
if anyone does get this upgrade let us know cause if it works good i'll go without a car for a week for the power difference
04sev6camry is offline   Reply With Quote
Old 06-28-2004, 08:33 AM   #10 (permalink)
Buy a ECU from junkyard and you're done
