Clear Corner Installation help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2003, 04:05 PM   #1 (permalink)
SekziCamry's Avatar
View SekziCamry's Photo Gallery
Exclamation Clear Corner Installation help
I just recieved my clear corners for my '99 Camry and am having a little problem with installation. I can take off the main screws, however there seems to be holding the stock corners back, like some sort of a hidden screw or something. Also when the stock corners do come off what do I need to do to connect/hook up the clear corners. Here are some pictures that may give you an idea as to what I am talking about. Thanks
http://warpeddream.netfirms.com/clea...arcorners.html
SekziCamry is offline   Reply With Quote
Old 10-30-2003, 04:11 PM   #2 (permalink)
Mr. A. Wong
grapefury's Avatar
View grapefury's Photo Gallery
the corners slide out toward the front of the car, there's like a clip thing that you need to un-clip. its kinda buried in there, but you should find it
grapefury is offline   Reply With Quote
Old 10-30-2003, 04:12 PM   #3 (permalink)
SekziCamry's Avatar
based on the images, could you give me an idea of where it is located please ?
Old 10-30-2003, 04:20 PM   #4 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
WIGGLE AND PULL! Its not that hard! Detach the clip, put your hand behind it... and then pull it out!
Brandon
arcasmachineracing is offline   Reply With Quote
Old 10-30-2003, 04:35 PM   #5 (permalink)
SekziCamry's Avatar
Its not that its hard, I just dont know what clip your talking about ;( or where it is.
Old 10-30-2003, 04:57 PM   #6 (permalink)
sargdesigns
I don't a have a new kamuurri so I am just guessin'! If its anything close to the gen 3 all ya gotta do is unscrew, and remove... front part first, and then side part next (I got a 94 with the 2-piecers... heh) but yea, DO YOU HAVE A FSM??? It would help ya bro!
Brandon
Old 10-31-2003, 12:39 PM   #7 (permalink)
SekziCamry's Avatar
Thanks guys for your help, I did it, I just needed to apply way more pressure. I thought I was gonna break it, but everything worked out.
