Darn, stripped SS line, but just slightly - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2003, 05:51 PM   #1 (permalink)
threedom's Avatar
View threedom's Photo Gallery
Question Darn, stripped SS line, but just slightly
How can I cut the line and reflare it, where to get stuff & what to get?
Will Goodridge help me out with a brand new line that I stripped a couple threads, or can I tap it myself or ???
I don't know if you can easily get a tap for that type of thread.
The problem was that the nut itself flared a bit and I had trouble getting it out and into the SS line. I then forced it into the new line, bad idea.
I was able to put it back into the stock line and get the car on the road. Since it was the last line I now have 3 SS and 1 stock.
Well, at least I have fresh ATE Superblue fluid (first change).
Any help greatly appreciated, thanks a lot!
1995 Toyota Camry LE
Silverleaf Metallic
36k miles
KYB GR-2 struts
Goodridge SS brake lines
Hella Micro DE foglights
threedom is offline   Reply With Quote
Old 11-01-2003, 06:52 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
So which fitting is messed up? The one on the car or the one on the ss brake line?
"Skoolin' the unlearned!"
Old 11-01-2003, 07:39 PM   #3 (permalink)
threedom's Avatar
the line, except it's stripped because the one on the car is too wide at the bottom, it's a bit flared. Musta happened at the factory.
Silverleaf Metallic
36k miles
KYB GR-2 struts
Old 11-02-2003, 01:39 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
Just cut off the messed up fitting and get another one.
The best thing for you to do is bring the line with you to a place that sells performance plumbing parts (ss lines and AN fittings). They'll be able to match the fitting and tell you what you need.
Old 11-02-2003, 08:43 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
I'm not sure what kind of fitting is on your ss brake lines, but its probably something like one of the 2 below:
http://www.holley.com/HiOctn/ProdLin...E/6001902.html
http://www.holley.com/HiOctn/ProdLin...HE/640603.html
And about the line on the car being flared. Its suppose to be, thats how it seals.
