Help, Throttle feeling diffrent!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2003, 08:53 PM   #1 (permalink)
sargdesigns
arcasmachineracing's Avatar
View arcasmachineracing's Photo Gallery
Question Help, Throttle feeling diffrent!?!
HELP!
My gas-pedal is feeling like it is kinda hesatating at about half-throttle... I feel this little "sticking" like sensation in the throttle when I am pressing and passing a certian point, and when I release and pass the same point... what the fuck is going on?
I am gonna go look at it more... Man, I feel like such a noob... I took off the breater-tube from the throttle body-to the crank-case today because I was gonna be working on polishing my valve cover... but never got around to it... I ended up replacing the tube, attaching everything, and now I can't figure out whats going on... help me out guys!
Thanks!
Brandon Mendez
Brandon
arcasmachineracing is offline   Reply With Quote
Old 11-03-2003, 09:14 AM   #2 (permalink)
sargdesigns
* Bump! Come on, are you guys stumped?
Brandon
Old 11-03-2003, 09:37 AM   #3 (permalink)
not actual size
brink's Avatar
View brink's Photo Gallery
I dunno, man. I'd say cleaning the throttle may turn the trick, but that's a guess. Typically it sticks right when you press on it if it's throttle. When you say breather tube, you talking about the PCV valve?
-- Jonathan W.
http://fleshy.org.nz/
brink is offline   Reply With Quote
Old 11-03-2003, 01:32 PM   #4 (permalink)
sargdesigns
Its more of like a tube... it comes from the throttle body to the side of the crankcase... damn it, I need an engine pic so I can show you it!
Brandon
Old 11-03-2003, 06:37 PM   #5 (permalink)
sargdesigns
LOOK DIRECTLY UNDER THE SPARKPLUG WIRES, closest to the valve cover, you see the black tube going into the crank case... thats what I changed out yesterday...
Any clue what the hell is going on???
Brandon
Old 11-03-2003, 07:37 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Have you tried turning the butterfly valve on the throttle body while looking at it to see if it sticks?
Also check the throttle / cruise control cables to see if their sticking.
"Skoolin' the unlearned!"
Old 11-03-2003, 09:35 PM   #7 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
I'd put my money on prob's in these areas.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 11-03-2003, 09:51 PM   #8 (permalink)
sargdesigns
Yep... first thing... I'll check cruise-control tonight...
Brandon
Old 11-03-2003, 10:15 PM   #9 (permalink)
Oh, and I forgot to mention the tube you speak of is the crankcase breather. The vaccum in the manifold prevents over pressurizing the crankcase.
Old 11-04-2003, 09:40 AM   #10 (permalink)
sargdesigns
Yeah, I know that! :P Couln't find anything hanging in the cruise control... it didn't seem as bad today... but I can still feel a slight "hanging-sensation" when I get on the gas...
Whats going on guys???
Brandon
Old 11-04-2003, 11:25 AM   #11 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
i know the problem!
your throttle is sticking!
but uhm....seriously
i'm guessing its just something in the way of the throttle cable, have you tried playing with the butterfly? i just have this feeling that this is what it is....
alex is offline   Reply With Quote
Old 11-04-2003, 01:56 PM   #12 (permalink)
sargdesigns
Originally posted by alex
i know the problem!
Jeezze guys! How many times are yall gonna ask me this! Yes! I played around with the throttle-butterfly, with out any resolution! It seems to be going away... a little bit, but I dunno what the hell is going on!
Brandon
Old 11-04-2003, 02:08 PM   #13 (permalink)
DJModifyd
alex's Avatar
did you check the pedal itself?
maybe its hittin something......check inside the car, your problem could be there to then.
also check the whole throttle cable.....starting inside the car with the pedal.
Old 11-04-2003, 03:39 PM   #14 (permalink)
sargdesigns
MMkay, I'm in school right now, tho...
Brandon
Old 11-04-2003, 05:53 PM   #15 (permalink)
There's a post button?
View Yanahdi's Photo Gallery
I had a prob similar to this and it wound up that I just needed to clean the throttle body.
Once that was done the gas pedal stopped sticking and everything responded fine.
1999 Solara SE (5S-FE)
Eibach Springs
Bilstein Struts
Whiteline Swaybars (Front and Rear)
TRD Quick Shifter
A'pexi World Sport Cat-back exhaust
Ripp Mods Header
K&N Air Filter
RESISTANCE IS FUTILE
if < 1 ohm
Yanahdi is offline   Reply With Quote
