My Camry stalls in cold weather. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2003, 10:04 PM   #1 (permalink)
View TwinTurbo Power's Photo Gallery
Hello all, im new to this toyota forum and have a Q?
I noticed that my Camry stalls if I let go of the gas. Every now and then both my Camry and the Celica has starting problems, it will start, but will die if i dont keep my foot on the gas. I have replaced the Idle control valve once on the Celica, but the problem has came back a year later. Any suggestions?
1990 300ZX Twin-Turbo Stage 5+ 410RWHP 416 lbs torque
1998 Camry V-6 LE Stock
1998 Celica GT Convertible Stock
1987 Corolla GTS Twin-CAM Stock
TwinTurbo Power is offline   Reply With Quote
Old 11-02-2003, 10:25 PM   #2 (permalink)
'04 Camry XLE V6
Kooter's Avatar
View Kooter's Photo Gallery
The idle air control valve is the number one culprit for what you are describing. Most valves will last around 60K miles or so but it is dependent on numerous factors like; how many short trips are made, etc. Also, the problem usually shows up when the humidty is high. Once the valve starts sticking you might as well have it replaced because even though it may not stick each time it will get worse with time.
Kooter
Kooter is offline   Reply With Quote
Old 11-02-2003, 10:30 PM   #3 (permalink)
Kooter
Ya, true but those ICV part are freakin expensive!!! Like ~$200 I dont want to deal with that. Does anyone have a better supplier or place i can get a little cheaper?
Old 11-02-2003, 10:32 PM   #4 (permalink)
Also can it be cleaned, or repaired? I just want options.
Old 11-03-2003, 03:46 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Check this thread.
http://www.toyotanation.com/showthre...threadid=24159
"Skoolin' the unlearned!"
Old 11-06-2003, 01:13 AM   #6 (permalink)
Originally posted by 88 LE
Check this thread.
Hey man thanks for that link, very helpful of you!!
