'99 Camry does NOT Decelerate.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-16-2008, 10:33 AM   #1 (permalink)
View akasha4's Photo Gallery
My 1999 automatic camry (4 cyl, 2.2L) doesn't decelerate after I have reached any peak speed. It says at that speed. I could go from 0 - 50km/h and it will stay stuck at 50 until I brake.
Does this have anything to do with cruise control? What could the problem be?
akasha4 is offline   Reply With Quote
Old 04-16-2008, 03:07 PM   #2 (permalink)
Gameroom cash: $304355
I would check for a sticking throttle valve inside the throttle body. Clean the throttle body thoroughly when you are inside there, paying particular attention to cleaning both sides of the throttle valve and also where the valve comes to rest inside the throttle body. I would also clean and then lubricate all pivot points of the throttle cable.
Mike
Old 04-18-2008, 11:17 AM   #3 (permalink)
View solidg's Photo Gallery
I think there was a recall on th trottle cable
check with your dealer
solidg is offline   Reply With Quote
