Transmission Troubleshooting Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2008, 11:08 AM   #1 (permalink)
View slyfox75's Photo Gallery
I posted this on the Solara forum....but for the sake of traffic I'm posting here as well.
I have an 2002, 150Kmiles, 4cyl Solara with a transmission/Speed sensor issue.
The car will very smoothly jump out of gear at all speeds....and then go back into gear fairly smoothly as well after a sec or two. The check engine light comes on and gives the vehicle speed senor code.
Replaced the speed sensor.....same issue. So then shop says it's an internal tranny issue so they get a tranny out of a wrecked solara with 45K miles on it(supposedly. The new transmission is doing the EXACT same thing. Bring it into Toyota yesterday, they spend 6 hours on it and also say it is internal tranny issue(the "new" one is on it by now.....they never looked at the car with the original transmission on it).
SO......Here are my questions.
-What, if anything, else could through this code?
-If the cable from the sensor back to the ECU(assuming it goes straight back to computer) is chafed and shorting on the body would this cause same issue? I'm making a HUGE assumption that the ECU is setup in a way that if signal is lost to VSS, it tells shift solenoid to "go to neutral" to prevent transmission damage. Anyone know?
-Last Point....and this is what is leading me down the cut wire path. About 2 months before all this began, her car(fiances car) had the entire dash removed to fish out a dead creature....after everything was put back together, her "D" light on the console does not illuminate. All the other ones do(Park, Neutral, etc). So Initially I was thinking it was not engaging fully into drive and it was going from Drive to Neutral. To disprove this though I put the car in 3rd(light on) and the transmission still "slips". I'm thinking that something maybe cut that wire and another wire has since vibrated/rubbed enough that it will randomly short to the body and cause ECU/transmission to flip out.
-Will the car drive with the VSS disconnected?
-Is this the same transmission as is in similar year model 4cy camry?
slyfox75 is offline   Reply With Quote
