1999 camery water in spare tire well - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2008, 12:14 PM   #1 (permalink)
View wentzmb's Photo Gallery
I have water in the spare tire well. Trunk is otherwise dry. Suggestions to fix. Barry
wentzmb is offline   Reply With Quote
Old 07-05-2008, 12:53 AM   #2 (permalink)
View mark181's Photo Gallery
I have the same problem but I also have water in my wheel wells. Have you figured a solution yet?
mark181 is offline   Reply With Quote
Old 07-05-2008, 11:46 AM   #3 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
You could take out one of the rubber stoppers out of the spare tire well.
rty is offline   Reply With Quote
Old 07-06-2008, 06:42 AM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $911027
iTrader Score: 59 reviews
I have the same problem, but its in the jack storage area...I guess new rubber seals are needed....
I even took a flash light, folded down the rear seat backs, during a hard rain and crawled tho that hole(tough I'm a big guy) to see if I could pin point the leak....but I couldn't.
Maybe u can shut a "good friend" in the trunk, soak it real good with a hose, find the source of the leak that way....I just leave a large towel in with jack to soak up any leaks.
I'll fix it one day!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 07-08-2008, 01:56 PM   #5 (permalink)
View toyomoho's Photo Gallery
Have had this issue on other cars. Typically needed to pull the trunk side interior panels then follow the water trail upward. Often even when dry you can see a trail.
Issues included leaks where any exterior trim panels attachment brackets went through the body, leaking rear window seal, leaking rear taillight assy, leaks coming through side rusted out areas, leaks in upper trunk gasket area.
