The rear wiring harness (in the trunk) is relatively simple. You should be able to consult the wiring diagram for the trunk harness (available in the service manual...check your local library or your dealer's service department) and with the aid of a volt-ohmmeter, you should be able to isolate the problem in a few minutes.
First things first: Verify the integrity of the ground connections. Grounds are always white wires with a black stripe. If the grounds aren't solid, anything might work improperly.
Gaining access to the entire trunk harness is pretty simple. Pull the snap fasteners that hold the trunk liners in place, remove the liners, and it's all there to see.
At worst, you can get this harness from a junkyard car for a pretty cheap price, and just swap the whole harness (It has modular connectors) and be done with it.
CJ
