Hot Air coming out of Vents
My wife's 2004 Camry just started blowing hot air continuously out of the vents. It doesn't matter where you set the cool/hot dial, hot air keeps coming out. It feels like the A/C compressor is coming on when you push the button so I don't think that it's a compressor issue. The air is REALLY HOT, like you have the temp setting at max heat. Is there some sort of electrically controlled damper that may have stopped moving??? If so, is there a certain fuse that I should check?
