Hi all,
I just recently remembered to reset my ECU by disconnecting my battery after I've had my new exhaust on for about 5 months. (Doh!) I neglected to do this after I got my Apex'i WS exhaust. After re-connecting the battery I noticed a marked difference in the sound of the exhaust.
Is this normal or just psychological?
The only thing that the exhaust changed was the pipes after the cat, would this really change the flow characteristics enough to warrant a change in exhaust tone?
1999 Solara SE (5S-FE)
Eibach Springs
Bilstein Struts
Whiteline Swaybars (Front and Rear)
TRD Quick Shifter
A'pexi World Sport Cat-back exhaust
Ripp Mods Header
K&N Air Filter
Well, initially it'll change the way the engine runs as it relearns how to run your engine again. After that, when it's learned how to run with the new exhaust, it sees different combustion behavior with the freer flow, so it's gonna provide different a/f ratios and thus change the way the engine sounds.
hi
i just reset my ECU by disconnecting my battery and after 15 mins later i connect the wire back and turn on my engine. i noticed that my engine shakes really hard and make a weird noise, too. but after 2 mins later it stop shakeing. so is that normal?
thanks
Just re-learning the fuel trims & more than likely was having to adjust the ignition timing at the same time.
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
