How to tel if 99 Camry has external amplifier? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2008, 08:35 AM   #1 (permalink)
View trfish's Photo Gallery
I have a 4 cylinder 99 Camry LE with factory CD player (not 6 CD changer). No sunroof, and cloth seats, if that matters. I want to add a parrot ck3100 car kit. There are two wiring harnesses: one for Camry's without an amp, and another for Camry's with the amp. How do I tell if mine has the amp?
Thank you in advance!
trfish is offline   Reply With Quote
Old 04-29-2008, 03:47 PM   #2 (permalink)
View toyomoho's Photo Gallery
The harness without the amp appears to have 2 -plugs, the remote amp harness something like a single 15 pin plug.
Old 04-29-2008, 05:01 PM   #3 (permalink)
what I meant to ask...
Thanks for the response. What I meant to ask is: how do I tell if my Camry has the amp (i.e. how do I determine which harness I need to buy?). Did you mean I should take out the radio and see if it's connected to the car via one or two connectors to the car's harness?
Old 04-29-2008, 07:39 PM   #4 (permalink)
View HighDef's Photo Gallery
More than likely it is a NON-JBL, which means you would need the TOY-1
Usually if the car is not fully loaded and if there is no JBL logo on the radio, you do not have a amplified JBL system. If you want to be certain you can call the dealer.
I think you have the standard radio!
http://www.safewireless.com/hands-fr...oy1-p-111.html
HighDef is offline   Reply With Quote
Old 04-30-2008, 07:52 AM   #5 (permalink)
Thanks!
There is no JBL designation, and it was not fully loaded (i.e. no sunroof or leather seats; not an XLE). I've not had very good luck with dealers, so I'm going to assume that it's the non-JBL version.
Thanks for the help.
Old 05-05-2008, 11:40 AM   #6 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
I would play the radio with bass turned up with engine on, then turn engine off and key in ACC position, if the sound is hollow, or bass is lost, then the amp has turned off.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 05-05-2008, 01:59 PM   #7 (permalink)
Thanks. I bought the parrot ck3100 and the toy-1 wiring harness from safewireless. Outstanding service, and the kit works fine in the car. So I must not have the JBL :-)
