Cheap fix for oil leak? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-01-2008, 10:37 PM   #1 (permalink)
View alegory's Photo Gallery
I have been told instead of paying big money to have a main seal repaired because of the labor of "pulling the engine" and so on, that you can simply use a product like J.B. Weld to seal where the leak is, about six dollars and you can do it yourself. Smart & cheap?, or not?
And for that matter any leaks at all, be it transmission, rear axle etc.
alegory is offline   Reply With Quote
Old 05-02-2008, 12:51 AM   #2 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
You can't JB weld when a seal is leaking.
A seal is mainly used when there are moving parts are involved. The main seal rides on the crankshaft. So it's constantly moving.
JB welding would seal it...until you start it. Then it'll start leaking again.
Plus you still have to pull the trans/motor out to gain access to seal it.
Nad1370 is offline   Reply With Quote
Old 05-02-2008, 01:27 PM   #3 (permalink)
Gameroom cash: $304355
If you are going to try anything, try one of those oil stopleak additives that you pour in to the oil. They claim to swell the seals a bit. It probably won't work to stop it, but maybe it will slow it down a bit. That's where I would invest my $5 or $6 before pulling the engine and trans to do the repair properly.
Good luck.
Mike
Old 05-09-2008, 04:13 PM   #4 (permalink)
View marc780's Photo Gallery
no there is no quick fix for a rear main seal leak...if you try one you are wasting your time and money. engine or trans has to come out, unfortunately.
