Location of ECU on Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2003, 09:19 PM   #1 (permalink)
Electronics master
View cmjohnson's Photo Gallery
Where is the ECU located on my gen III Camry, anyway?
Somebody told me once that it was the box located under the center console between the seats, but I now know that this isn't true. That unit is the airbag deployment sensor, I'm pretty sure.
So where is the ECU?
I want to know because I want to get another ECU and send it off to be performance modded for my type of car and motor, and then put the original ECU in storage for safekeeping and as a backup. And I'll probably be doing the installation myself, and I'll probably have to pull it out of a junker myself.
CJ
cmjohnson is offline   Reply With Quote
Old 11-11-2003, 10:20 PM   #2 (permalink)
View evilragu's Photo Gallery
i believe think..... that it is behind and up the glove box
evilragu is offline   Reply With Quote
Old 11-11-2003, 10:45 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
cmjohnson, you're correct. The box btw the seats is the airbag brain/sensor.
The ECU is tucked behind the glovebox.
Where were you thinking of sending the ECU?
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 11-12-2003, 12:19 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Yup its behind the glovebox.
"Skoolin' the unlearned!"
Old 11-12-2003, 02:26 AM   #5 (permalink)
View phatboy555's Photo Gallery
aren't most ecu's just behind the glove box
phatboy555 is offline   Reply With Quote
Old 11-12-2003, 08:41 AM   #6 (permalink)
Electronics master
I'm still researching where to send the ECU to get it hotrodded.
Got any suggestions?
It's for a stock '92 V6 without ABS.
CJ
Old 11-12-2003, 08:46 AM   #7 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $700265
iTrader Score: 6 reviews
View EKam's Photo Gallery
Toyota ECUs are not programmable.
You'll have to get aftermarket ECU with full manual tuning which is $$$$ and $.
Just get Apex'i SAFC instead, not like there's any advantage an aftermarket ECU will provide to V6 engine unless you're doing something really crazy.
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
