Rear end clunking - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2008, 09:29 PM   #1 (permalink)
View Robertch's Photo Gallery
USA Rear end clunking
I have a 1999 Camry with 125,000 miles. When going over bumps, there is a loud clunking from the rear end. It does not occur much when I am alone in the car, but it is TERRIBLE when I have back seat passengers and luggage in the trunk. A dealer supposedly replaced the rear sway bar bushings, but the clunking persists. Any ideas??
Robertch is offline   Reply With Quote
Old 05-23-2008, 01:14 PM   #2 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
It could be anything. First, check the struts, strut mounts, and sway bar end links.
2006 Camry LE Special Edition
Old 06-08-2008, 10:05 PM   #3 (permalink)
View Kaline's Photo Gallery
Robertch:
Jack the car up and check all the bushings. If the bushings look OK, then it is probably the strut mounts.
My wife's '99 Camry has the rear lower control arm bushings wear out at about 90K miles, only on the left side of the car. We had the entire arm assembly replaced and it has been fine ever since (at 130K right now).
Best of luck.
Kaline is offline   Reply With Quote
Old 06-09-2008, 12:35 AM   #4 (permalink)
View toyomoho's Photo Gallery
Have someone drive the car while you listen in the rear seat to the upper strut mounts. The mounts are under the rear deck outside of the speakers.
