Radiator Fans - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2003, 06:20 PM   #1 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
Radiator Fans
On gen 3 5SFE's, is one of the radiator fans supposed to be operational all the time? When I turn the a/c on, both fans turn fast, but when its off, nothing moves.
Thanks for the help, I'm trying to figure out if my engine is overheating and my instrument panel temp gauge is malfunctioning.
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 11-13-2003, 08:47 PM   #2 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
The fan should turn on as needed. The coolant temp is the deciding factor to if it runs or not. If it does not run at all without the A/C, something is wrong there and not with the temp. gauge.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 11-13-2003, 10:25 PM   #3 (permalink)
Deuce's Avatar
cool...thx 4 da help
Old 11-13-2003, 10:27 PM   #4 (permalink)
eecc's Avatar
View eecc's Photo Gallery
jus a question out of curiosity, do the fans blow at the radiator or blow towards the engine?
eecc is offline   Reply With Quote
Old 11-14-2003, 01:05 AM   #5 (permalink)
View mdvb747's Photo Gallery
They blow to the engine.
mdvb747 is offline   Reply With Quote
Old 11-14-2003, 10:13 AM   #6 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Have you tried pulling the plug from the ECT (engine coolant temp) sensor to see if the fans kick on?
I forget if you just pull the plug or if you have to pull the plug and short the 2 wires on the connector together.
"Skoolin' the unlearned!"
Old 11-14-2003, 12:07 PM   #7 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Yup. "Puller" type fans, meaning they pull the air thru the rad. "Pusher" type would be mounted in front of the rad.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 11-14-2003, 09:32 PM   #8 (permalink)
View OEMonkey's Photo Gallery
the fans will only come on when your idling or at low speed. when your cruising it gets ram air so it wont need the puller fans.
when you turn the ac on, the fans will come on to help the condenser dissipate heat.
when your idling at operating temps.(175-195deg. F depending on what car), the fans will come on. they will not come on if the car is cold.
or do what 88LE said and unplug the ECTS. the fans should kick in. if not, check the fuses, main fan relay, or there might be a short between relay and ECTS.
OEMonkey is offline   Reply With Quote
