If your Camry has rear drums, the handbrake can be adjusted with a phillip screw driver by taking off the rear drum and adjusting the small gear. But be very careful you don't tighten too much or you will not be able to move the drum causing it rub and overheat and warp.
If you have discs in the rear than I believe you have to take the mid section console off and adjust the handbrake near the handbrake lever.
Someone correct me if I am wrong!
92 Camry 4 cyl 5 Spd
390,000km, Retrofited Projectors + 6000k HID, 2500k Fogs, SRI, K-Sport Coilovers, TRD Rear Sway Bar, GEN4 Ralco Short Shifter, Alpine 7" IVA-D900, 2 x 10" MTX / MTX 900W Amp
