Originally posted by drive
Does anyone have rim and tire size specifics for a 97 4cyl Camry with stock 14inch rims? We are looking at getting 15in rims but are confused at what the rim and tire specifications need to be for 15s.
Thanks
If you've used the search function on this forum
, you'd have found something like this:
The stock Camry 15" wheels should fit yours, if this is what you are looking for. The tire should be 205/65-15. The bolt pattern is 5-114.3, centerbore is 60.1. Just go to
http://www.discounttiredirect.com or
www.tirerack.com and play with the optional sizes to find what you can use. The offset should be about +42 mm.
But why go from 14 to 15? Not much difference at all... Go to 16 if you want a still cushy ride; get 17 for better handling but somewhat rougher ride...
