This is probably a little stupid, but I want to make sure. Yesterday, I went to a local junkyard, and got a new flex pipe since my old one was nearly torn in half. Nice and loud. After installing it, I shook the engine around a bit to see if it was ok, and I noticed a slight clanking sound coming from the rear engine mount near the firewall. Upon further investigation, I found that the engine was not attached to the mount (I'm assuming this is the engine mount: rectangular piece of rubber on the crossbar thingy), and that the engine was bumping up against it when pushed from the mount by the radiator.
I noticed that there were no bolts where it should have been connected to the engine. I poked a small allen wrench into the holes to make sure there weren't any broken bolts stuck in there, and there aren't. Now, the problem is that there's no sign of bolts ever being in there, so I'm not sure if they should be. Common sense says yes, but you never know...
Should I have bolts in there? I need to know what size they are so I can buy them tomorrow. It's a 1989 3S-FE 5spd. Thanks.
Oh yeah, and at the junkyard, I found an older 87/88 Camry. It had some folding mirrors (Not motorized folding, I checked). They were pretty cool, and I never knew the more "luxury" models had that.
