short shifter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2002, 01:27 PM   #1 (permalink)
View red wraith4's Photo Gallery
Does anyone know if the gen4 TRD short shifter is compatible with the gen3 cams? I was thinking of putting that on for my '93 SEV6.
red wraith4 is offline   Reply With Quote
Old 02-23-2002, 01:33 PM   #2 (permalink)
TN Legal Team
View SpectraBlueCam's Photo Gallery
One of our members, Darryl, is looking into doing the exact same for his Gen3 5spd V6. The word is that a Gen4 shortshifter will fit, though I haven't seen it done personally.
I'm SUPER, thanks for asking;
All things considered I couldn't be better I must say.
I'm feeling SUPER, no, nothing bugs me;
Everything is SUPER when you're...
SUPERCHARGED!
SpectraBlueCam is offline   Reply With Quote
Old 02-23-2002, 02:35 PM   #3 (permalink)
View soundlzrd's Photo Gallery
Justin, aka wraith, has done it. i am also looking at it. i guess the only problem is, with the shift is some things on the side that you have to remove. im trying to contact him, and ask him about it
soundlzrd is offline   Reply With Quote
Old 02-24-2002, 12:22 AM   #4 (permalink)
Luc
View Luc's Photo Gallery
I just got my TRD short shifter on Friday, ready to be installed in my Gen3. Hopefully, I'll have some pictures to go with it just to see what the differences are.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
Luc is offline   Reply With Quote
Old 02-24-2002, 11:21 AM   #5 (permalink)
Luc, that would be great, and very helpful! thanks
Old 02-24-2002, 05:26 PM   #6 (permalink)
Luc
Ok, I just tried to put the TRD short shifter onto the Gen3...and, it didn't work. The bottom half of the ball was about 1" longer than the stock one. Thus, the shifter base wasn't able to be seated at all. In addition, the bottom linkage was hitting the floor also. Everything else was a perfect snap. Mao took some pictures and hopefully, we'll get those uploaded to let you know what we saw. I've already e-mailed Wraith about how he adjusted it to fit. So hopefully, he can provide some good advice.
Ideally, it would be possible to get it to fit, by elevating the mounting base by adding an extension. This would require longer bolts, but the OEM bolts are actually welded from the bottom of the mating base that shifter base sits on. So far, that's my observation.
Luc
Old 02-24-2002, 11:30 PM   #7 (permalink)
Luc
I got words from Wraith about the short shifter and he said that I need to get the Gen4 shifter assembly to make it work, after clipping some tabs off. So, the story hasn't ended just yet.
Luc
Old 02-26-2002, 04:53 PM   #8 (permalink)
Luc
Here are some pictures of the foiled attempt to put the TRD short shifter in my Gen3.
http://www.imagestation.com/album/pictures.html?id=4292011851
Luc
Old 02-27-2002, 08:35 AM   #9 (permalink)
View DS - TTCC's Photo Gallery
Could you not add some bolt extensions or something to that so that it would at least bolt up? Will the TRD shifter shift the car into gear? My suggestion would be to remove the entire shifter assembly, cut off the studs that are welded in, then drill and tap for some new bolts. Then, use some steel sleeves to make up the height you need, bolt it in, and go!!! Let me know if this works.
DS
1992 V6 3VZ-FE Camry, 5 speed!
DS - TTCC is offline   Reply With Quote
Old 02-27-2002, 10:54 AM   #10 (permalink)
Luc
Yeah, that's the first thing I thought about: take the bolts out and add some longer ones, while adding an extension to support the shifter base. I'm sure this process would be much cheaper than to get a Gen4 shifter assembly. The TRD one does seem to work when I shifted into gears, since both linkages connect up.
Luc
Old 02-27-2002, 12:44 PM   #11 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112150
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
How high does the plate sit above the bolts? Can you get an exact measurement?
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 02-27-2002, 03:37 PM   #12 (permalink)
Luc
Hmmm...that last picture showed how high it sat above the mounting base, about 1.5" at least. This is with the bottom linkage on the floor though. So I figure it may need at least 2" higher. I will try to get an exact measurement when I have another chance, but that's my guess for now.
Luc
Old 02-27-2002, 03:58 PM   #13 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
cool, that'd be great! I've been meaning to check the clearence from the floor on the OEM shifter too. I want to lengthen the bottom half and shorten the top half of the OEM stick, weld it up, sand it and if it works well... cast it, and pour a solid aloy shifter.
