3VZ-FE valve clearance check... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2003, 11:40 AM   #1 (permalink)
cui
View cui's Photo Gallery
v6 3VZ-FE valve clearance check (timing)...
If the crank is at TDC for number 1....how much do I have to rotate (clockwise) to get 2nd cylinder to TDC?
and, where will the cam marks be aligned to?
(I tried the cloth hanger method...but wanted to know the right way...)
cui is offline   Reply With Quote
Old 11-21-2003, 12:14 PM   #2 (permalink)
cui
anyone?
Old 11-21-2003, 04:50 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
With a 4 stroke engine it takes 720 degrees of crank rotation to fire a cylinder.
Since you have a V6 a cylinder fires every 120 degrees. 720 / 6 = 120.
Firing order on a 3VZ-FE is 1,2,3,4,5,6 so if #1 is at TDC #2 would fire 120 degrees after #1.
The cams rotate at half the speed of the crank. When the crank does a full revolution (360 degrees) the cam is at 180 degrees. So if #1 is at TDC (cam also at TDC) the cam will be at 60 degrees when #2 is at TDC.
By the way don't you have a repair manual?
"Skoolin' the unlearned!"
Old 11-21-2003, 06:50 PM   #4 (permalink)
cui
88 LE, you are the man. Not only you told me the answer, but also explain it very well. Big thanks!
And, no repair manual here....I figure I can do most of the stuffs without an manual....(I will probably going to get a cheap haynes/chilton in the future even though I know the OEM is the best....btw, I just got the car like 10 days ago.)
Old 11-25-2006, 06:41 PM   #5 (permalink)
View toyomoho's Photo Gallery
Go to the link below and find the sevice manual for this generation car.
http://oregonstate.edu/~tongt/camry
