Why not just build it up yourself. Any performance head that you're going to buy is just stuff that you could do yourself + a markup for the total package. Find a local machine shop and find out how much a p&p, angle, mill is. Crower will regrind your cams for 150$. You can use 4age valve springs to give you a bigger redline, those run about 150$. I'm sure you can find a local car junky that knows how to p&p, that'll probably be cheaper than having a pro shop do it.
3S-FTE: 9.3:1 compression + 5psi = owns you!
