squealing/squeaking noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2003, 01:02 AM   #1 (permalink)
View 97Camry/blue's Photo Gallery
My 97 camry 4cyl makes squealing/squeaking noise when I make a sharp right turn to park in the parking lot. It only makes that type of noise when I do that. I had my rack and pinion replaced in August 2002 and left boot replaced on September 03. What could be the prob?
97Camry/blue is offline   Reply With Quote
Old 11-19-2003, 01:33 AM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $396560
iTrader Score: 13 reviews
sharp turn + a squealing noise??
tires.....:p
HaHa
Old 11-19-2003, 02:59 PM   #3 (permalink)
View dj14901's Photo Gallery
It's most likely the rubber grommet where the steering shaft passes through the firewall. Spray some silicone spray where the shaft and grommet connect, and you should be all set. Here's a pic:
http://public.webbox.com/index.asp?p=595606&ls=1
HTH -
DJ
dj14901 is offline   Reply With Quote
Old 11-19-2003, 03:54 PM   #4 (permalink)
HTH -
DJ
The noise comes from the outside, on dry surface, and for some reason it only happens in parking lots.
Old 11-19-2003, 04:58 PM   #5 (permalink)
OLD TN dude
View MCTOY's Photo Gallery
parking lot squeek
Based on what your saying, sounds like when you run over the painted lines in the parking lot. I know that at 'full turn' in all my cars the tires slip sideways a little when they are on the paint lines. They dont do it on the road because you arent putting that much sideways torque on the tires, plus the highway crews put a sand like material on the road markings so that they wont be so slick. Cheapskates at Walmart dont....
Just one idea
MCTOY
MCTOY
"I am not ashamed of HIM, in whom I have believed."
MCTOY is offline   Reply With Quote
Old 11-19-2003, 06:01 PM   #6 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
Power steering belt, or metallic brake pad (or wear indicators) on rotor.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 12-08-2003, 12:05 PM   #7 (permalink)
View etam's Photo Gallery
HTH -
DJ
what silicone spray to use?
thanks
etam is offline   Reply With Quote
Old 12-08-2003, 01:02 PM   #8 (permalink)
It doesn't really matter which silicone spray you use, just make sure it's a lubricant and NOT a sealant! If you got to your local auto parts store (I'm not sure if you have a Pep Boys or Autozone up there) and ask them for some silicone spray, they should be able to help you out...
DJ
Old 02-20-2004, 07:59 AM   #9 (permalink)
View haa21's Photo Gallery
Has anyone found a solution to this problem?
I checked my fluid and it was at a proper level. I did top it off. I lubricated the steering column both indise the car and behind the firewall with a silicon spray. I still notice I get noise. I check the hoses (as best I could see without gettingunder the car) and I don't see any signs of leakage. The weather has warmed up to in the 40's here and I still here, so, I doubt if it is the cold weather. Someone has mentioned the belt, but if the belt was loose wouldn't it squeal all of the time or at least everytime I tunred the sterring wheel?
haa21 is offline   Reply With Quote
Old 02-20-2004, 08:24 AM   #10 (permalink)
View tightcamry129's Photo Gallery
you know what, have your wheels aligned. A while ago, when i made sharp right turns at high speeds, it made squealing noise. I didn't think much of it. Couple months later when my car was due for an alignment, it turns out that my right front toe was way off!!!
tightcamry129 is offline   Reply With Quote
Old 02-20-2004, 10:24 AM   #11 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
is it only when the wheel is cranked all the way over
does it stop if you bring the wheel back a bit (from cranked all the way over)
-Nick
Nick is offline   Reply With Quote
Old 02-23-2004, 05:26 AM   #12 (permalink)
I could try getting an alignment. I don't have any signs that the car is misaligned, but it is something to look into.
No, I don't have the wheel turned completely. In fact, since the noise started I have tried to back out turning the wheel as little as possible! The noise seems to be loudest when you start to go forward and you are turning your wheel to straighten out. It is only there for a second.
Does the Camry have a specific belt for the power steering pump on the V6 engine?
Old 02-23-2004, 10:05 AM   #13 (permalink)
Nick's Avatar
yup, power steering has its own belt, (on 3vz that is) don't know about the 1mz
-Nick
