chech the tops of each tank. each top should have two hoses gong to them. undo the hoses and turn the cap half way around and put the hoses back on. i know for a fact that the antifreeze tank has a one way cap, if you have the lines on backwards then fluid will come out. this happened to me. try switching the hoses on each first and see if it still leaks, if it does then switch them back and see what happens or you really do have a leak somewhere.
when i painted all the tops to my tanks i put the antifreeze top in backwards and fluid was coming out, i thought i had a leak and could never find it. one i day i decided to look at the top and saw that it had to go on a certain way. so just check and make sure it's on the right way.
