Need Help SuperFast!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2003, 10:27 PM   #1 (permalink)
View fe519's Photo Gallery
i told everyone i was going to change my differential fluid yesterday and i just flushed the fluid out. But when I refilled it, it only took about 1 qt and it started to dribble out already. Do you think 1 qt is safe to drive? can someone refer me to a tool that i can use to refill the differential? i need help asap! thanks everyone
fe519 is offline   Reply With Quote
Old 11-21-2003, 10:32 PM   #2 (permalink)
wvagravehunter's Avatar
View wvagravehunter's Photo Gallery
The best thing that I can say for you to use is an oil can with a pump-type handle. That's what I used for mine. Although I'm pretty sure that the differential should take a little more than a quart, there may be some differences with different models. What model do you have? I hope I can be of some help, but you never know. But seriously, try the oil canister....it works.
'99 Toyota Camry LE
wvagravehunter is offline   Reply With Quote
Old 11-21-2003, 10:49 PM   #3 (permalink)
same camry you got in your picture, except a 98. u think its ok to run with 1 qt in there?
Old 11-22-2003, 11:22 AM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You have to fill it up with the car level to the ground, not up on jackstands.
It should take about 2 quarts to fill it up.
I use a funnel with a hose shoved onto the end of it.
"Skoolin' the unlearned!"
