Can you just slip the timing belt on the v6 3VZ-FE?
I aligned all the marks correctly...but if I simply slip in the belt and tighten the tensioner...do a 720 degree crank rotation...then my crank mark points to 5 degree retarded...ie, missing one tooth at the crank.
I removed the belt and re-did the same process...same result, 5 degree retarded.
Why? How would you do it?
(I ended up "solving" my problem by purposely mis-align the crank pulley by one tooth...then, everything checked out okay....but this is just doesn't seem right in my book.....)
