1993 camry le wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-11-2008, 02:12 PM   #1 (permalink)
View joshishustlin's Photo Gallery
my 93 camry le wont crank up, when i turn the key it makes a click sound but doesnt try to crank.. can anyone help me out?
joshishustlin is offline   Reply With Quote
Old 07-11-2008, 03:04 PM   #2 (permalink)
Gameroom cash: $304355
A single click is usually an indicator of bad contacts in the starter's solenoid. This has been covered numerous times. Do a search on this forum for "starter contacts" and read up on the problem and it's possible cures. You can varify this problem by tapping on the starter's solenoid while someone holds the key in the start postion. If the starter now turns, you have varified this problem.
If you are getting multiple rapid clicks, this usually indicates a weak battery, poor or corroded connections at the battery or starter, or bad cables between the battery and the starter. If the battery is weak, you need to check out the entire charging system; battery, alternator and alternator belt.
Mike
Old 07-12-2008, 12:51 AM   #3 (permalink)
thanks
thanks for your help but i saw that way to hit it with a hammer to make it crank, will that make it start, and is there a specific place i hit it or does it matter? im sure people have already asked this but i cant find what im looking for. please help
Old 07-12-2008, 10:32 AM   #4 (permalink)
Tap the solenoid itself. It's the little cylinder shaped object on top of the much larger cylinder shaped object. The much larger cylinder shaped object is the starter itself. They sit horizontially and are located on the front of the engine block on the driver's side. Give it a good tap, but not hard enough to break it or crack it. If it begins to crank this way, yes it will start.
Mike
Old 07-17-2008, 01:45 PM   #5 (permalink)
i tried that but it wont crank up still, do you have any other sugestions to make it crank?
Old 07-17-2008, 02:35 PM   #6 (permalink)
If it's bad solenoid contacts, that usually makes it crank. Did you hit the solenoid fairly hard? Have you checked the battery cables at the battery terminals for tightness and possible corrosion? Have you tried jump starting it from another vehicle?
Mike
Old 07-17-2008, 04:25 PM   #7 (permalink)
rty
Gameroom cash: $298766
View rty's Photo Gallery
I had the same problem. If I did it enough times it eventually cranked. It was the starter.
rty is offline   Reply With Quote
Old 07-27-2008, 03:07 AM   #8 (permalink)
yea, i tried all that stuff but im sure its the starter, ima throw a new one in, thanks for the help
