HELP: shaking problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2003, 07:58 PM   #1 (permalink)
View quietflip2's Photo Gallery
i have a 92 camry and when i'm driving everything starts to ramdomly shake (dash board, steering wheel) at any speed. the shaking won't stop until i let off the gas. does anybody know what this could be and how i could fix it?
quietflip2 is offline   Reply With Quote
Old 11-25-2003, 08:55 PM   #2 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
Could be that your front wheels are off balance???
I only say this because you mentioned how the shaking is in the steering wheel, and dash....
Does it get worse and worse as you go faster and faster???
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
90CamryDx3SFE is offline   Reply With Quote
Old 11-27-2003, 02:32 AM   #3 (permalink)
Captain Insano
cleanG3on19s's Avatar
View cleanG3on19s's Photo Gallery
Need more info:
Could be lots of stuff:
Mine used to shake at certain speeds. But then I changed out my suspension, got new rims and tires, and an alignment and now is rock solid to 100mph and beyond. Got to test this out quite bit driving from NY to CA.
I would start at the tires, could be out of balance, or have a flat spot, or if your on aftermarket wheels coud be issues there too.
cleanG3on19s is offline   Reply With Quote
Old 11-27-2003, 08:11 AM   #4 (permalink)
Livers are for wusses
nobrainer's Avatar
View nobrainer's Photo Gallery
if you are shaking when stopped, it is most likely that you are idling too low (mine does this sometimes) ... I remember the smarter guys in here talking about cleaning your throttle body... maybe im wrong though
nobrainer is offline   Reply With Quote
Old 11-27-2003, 03:39 PM   #5 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
your tranny mount could be worn, and/or your axle(s) could be bent
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 11-27-2003, 05:02 PM   #6 (permalink)
the shaking gets really bad, not like shaking when wheels aren't balanced. It also looks like the hood is shaking as well, with the steering wheel and the whole dashboard. I also noticed it happens more when i'm on the freeway or trying to give it lots of gas. The shaking is never constant. i'll check the tranny mount, and thanks for the help
Old 11-27-2003, 05:10 PM   #7 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
CV Joints, ball joints, or split belts in a tire.
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 11-27-2003, 05:13 PM   #8 (permalink)
Deuce's Avatar
check your torque mount too (at the top of the engine bay). If its severely cracked, you got a $500 incl/labor mount replacement problem. $220 if you DIY (parts and tools)
