Seat belts can be over-rated, but it really is a good habit to get into, I mean at least to be safe, plus, in most places, it's the law. But as for the seat belt light, there are two ways you could go about fixing this...so here they are.
The easy & lazy way :
Take the instrument cluster out, and pull the bulb for that little light.
The more difficult way :
Remove the driver's side seat and pull it completely from the car, look from the seat belt buckle on the side of the seat and trace the wiring back from it to underneath the seat, find the connector from that wire, and disconnect it, and put the seat back into the car.
So now you have two options, but the good choice would be to wear your seat belt, at least when you drive fast, be a little cautious.
'99 Toyota Camry LE
