Clutch Pedal cath point - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2003, 02:52 PM   #1 (permalink)
View JayHood's Photo Gallery
Question Clutch Pedal cath point
I was just wondering if it was possible to lower the catch point on my clutch because it catches very high, and its killing me on the hills. Thanks in Advance.
Jarret
Jarret
1989 Camry, LE V6 5spd
Baby Blue
JayHood is offline   Reply With Quote
Old 11-30-2003, 12:12 PM   #2 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
Change to an aftermarket clutch.
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 11-30-2003, 01:48 PM   #3 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
Well i know that they are adjustable.......but i don't know how
- Vince
VVT-i Owns is offline   Reply With Quote
Old 11-30-2003, 01:56 PM   #4 (permalink)
I know you can adjust pedal height, but usually the "catch point" as you call it is determined by the clutch itself. My stock clutch was exactly as you describe, but my Centerforce took a little time to get used to. I kept stalling because the pressure point is just after you start letting the clutch out.
Old 12-01-2003, 11:54 AM   #5 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
Yea I know on my gen2 there's a way to adjust the clutch catch point, I'm not 100% sure how it is done, but since I tend to be a little fast coming off it I like a slightly higher catch point. However your clutch might be old and slipping and not biting as fast as it used to. I found that to be the case when I had the clutch redone last summer.
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 12-01-2003, 12:38 PM   #6 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Its adjusted on the pedal itself - at least on my Gen3.
There are two adjustments, clutch pedal height, and clutch pedal freeplay. The freeplay is adjusted by untightening the nut thats on the rod of the master cylinder when it attaches to the pedal. Then once the nuts is loose, you rotate the actual master cylinder rod either cloockwise (to make it engage lower) or counter-clockwise (to make it engage higher) - make sure you dont run out of thread though. The second adjustment is the clutch pedal height. There is a nut on the upper part of the clutch pedal assembly that adjusts this. Ive never had to so thats all i know.
hope that helps.
ratko.org
Ratko is offline   Reply With Quote
Old 12-15-2003, 09:41 PM   #7 (permalink)
View MJW1986's Photo Gallery
it may just need a new clutch, as it goes you need to let the clutch up more and more. Changing the catch point may hurt it but im not 100% sure
Its 100 miles to chicago, we've got a full tank of gas, half a pack of cigarettes, its dark and we are wearing sunglasses. Hit it- Blues brothers
MJW1986 is offline   Reply With Quote
Old 12-15-2003, 09:49 PM   #8 (permalink)
My car looks good wet
View 90CamryDx3SFE's Photo Gallery
Catch point... Pressure Point... Friction point...
So confusing...
Thank god I drive an Automatic
I would say swap for an aftermarket clutch
First Gen 2 with a Flowmaster
Shot transmission, but it's all good.
90CamryDx3SFE is offline   Reply With Quote
