#*&%!^ Exhaust! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-29-2003, 10:45 PM   #1 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
#*&%!^ Exhaust!
So I'm putting the snow tires on my Camry today (pimp, eh?)
and got around to the right rear tire. Now while it was off, I had to look at my exhaust right around the area of the muffler pipe flange and centerpipe flange. It has been getting loud, and I half-assedly looked last weekend to see that the muffler pipe, where welded to its flange, was badly rusted... Well I looked again, because it's much easier to see without that pesky tire in the way, and whaddaya know... a crack about 2/3" long and 1/8" wide! No wonder it was getting loud! I have a replacement muffler waiting to go (a V6 muffler- because it has two tips, so it's a looks-motivated decision), looks like a pretty easy job but I wonder how badly those flange bolts have rusted! Ahhhhhh... I can think of better things to do on a bitterly cold December day (planning to do it on Friday)
This sucks!
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 11-29-2003, 10:57 PM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
2nd gen camry's are known for blowing holes in there exhaust. I infact jsut replaced the mid pipe on my 89 this weekend because the weld to the resonator broke. My parents are the original owners of the 89 camry and in the time of owning it the head pipe has been replaced once, mid pipe now 3 times and it is on its third muffler. A tip for you though. Get some WD40 or some rust penatrant and soak the crap out of the bolts. Let the stuff sit on the bolts for about 5-10 minutes. That should help you out in taking the bolts out. Also make sure you have new bolts for it. I beleive the thread size is 8X1.25" and it is a 12mm bolt head.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 11-30-2003, 12:56 AM   #3 (permalink)
View jim99ce's Photo Gallery
a simpler way is to get a torch, and heat up the nut and nock it off with a small hammer...
the metal of the tubing is far better material than the bolts and nuts themselves... so they should be fine....
takes about five minutes...
jim99ce is offline   Reply With Quote
Old 04-28-2006, 10:16 PM   #4 (permalink)
Night Speed's Avatar
View Night Speed's Photo Gallery
so does any one know for the gen 4.5...what is the bolt size for the rear section of the muffler?
thanks
Night Speed is offline   Reply With Quote
